I've just received my new mitre saw, an Elektra Beckum KGS 331 with induction motor.
Im really loving it everything is so smooooth and it cuts so positivly and silently with an 80t Axminster blade i threw on it. The induction motor really makes this saw.
One thing i feel could be improved is the so called positve stop for the mitre angles, its a plastic lever that clicks into the detent but the plastic lever wobbles on the spindle its mounted on. This means the saw will move slightly 3mm ish if you try and move it meaning it would go off square or off whatever angle you had it set at. This is totally fixed when you tighten the clamp to set the saw in an infinate position but i feel you shouldnt need to do this when using it in the positive detents.
Unfortunatly mine was a second hand saw and it seems my electric brake is not working, blade now takes roughly a year to stop spinning, so i need to get this sorted.
But overall im VERY impressed i feel this saw is totally overlooked by most people.
