user 36867
- Joined
- 23 Apr 2021
- Messages
- 193
- Reaction score
- 80
Did you have to have planning permision
HiHi Martin
Great read, thanks.
I’m currently planning a very similar build, although located in AONB and well over 50m from dwelling house so planning req’d.
One aspect I’m currently mulling over... the old chestnut of metric/imperial, sheet materials and reduced cutting/waste.
I noticed you went for 400mm spacing (not centres) on floor joists as this allows minimal cutting of PIR. However, you went with 400mm centres on wall studs? What was your thinking with this?
It seems to me that whatever you do, something ends up needing cuts. Hard to win either way.
For example, going with 450mm centres on wall studs, works well for PIR but leaves cuts for outer OSB.
Thanks in advance for any thoughts you have on this!
Yes makes sense thanks Martin.
Floor...
I’ve previously used 18mm ply for flooring (albeit on smaller non-insulated ‘practice’ sheds) again sold in imperial. And I did line up the joins with joists.
I’m assuming the T&G boards don’t need joins fixing? If so, a good reason to use instead of ply. For my sheds, the ply was the final finished surface so better in that situation I think, resilience wise.
Roof... plasterboard would need to land on centres?
Walls... I notice Robin C mentions 11mm OSB is available in 2700mm lengths, divisible by 450mm into 6. This seems like a neat solution?
Excuse the slightly muddled thinking. I’ve had to put my sketches away because I was finding the question of centres and sheet materials utterly confusing. Then I discovered your thread. So thanks!
I think its a good idea to design your building around sheet materials in your case when you are not restricted to the 2.5m height of permitted development builds. Like you mention though, you still have the incompatibility / difference in height of the external OSB sheathing vs internal plasterboard, by the tune of about 120mm like you say (assuming you want the OSB to terminate exactly at the bottom of the joists - I would probably add another 30mm to help any drips keep away from the joists (assuming you have an air gap at bottom, which you may not, depending on your choice of foundations).Yes that’s where I was going with it...!
Plasterboard is also available in 2700mm lengths so I think that’s why Robin says it works so well.
In terms of wall height, that’s a very good point about internal height and I’ll have to give it some thought. Externally though, since I’m having to apply for permission and also aiming for a pitched roof, I can (attempt) a design to suit materials to some extent. Two sheets of horizontal osb give 2.4m which will include double wall plate, stud, sole plate, plus some overhang to cover flooring and over floor frame, so not unreasonable without cutting I don’t think. Internal height needs some thought ... I guess it’s similar but minus the floor joist overlap & T&G thickness? (c. 100mm + 18mm = 120mm).
I noticed you had single wall plate? I’m thinking double because the corners tied up nicely last time and also I’m going to keep frames at a size that I can handle when lifting to upright position, so planning a series of panels rather than larger widths. I found 2.4m widths just about manageable last time. Tbh the more complex walls with kings & trimmers etc almost killed me ...! So the double plate will help me tie the smaller panels together.
cheers
