Aug 2021 - Internal Walls and TV and Office Planning
Time to put up the wall between the office and the workshop. Oh yeah, and create a bathroom also. Quite a lot of learning in this stage
Partition Wall
The partition wall was very straight forward. First create a top and bottom plate and fix it into position. Then just measure the height of the required studs, and cut each stud and nail it in place, ensuring it is plumb. I used 400mm centres, as with the external walls, even though it isn't load bearing and probably doesn't need to be that strong. I wanted to keep it consistent to make finding studs easier, and also thought the added strength would be good with the bathroom door slamming shut all the time. I did use 4 x 2 though, instead of the 5 x 2 which I used for the walls.
Doors
This was the bit I was quite clueless about, I didn't know that door linings existed until I was building the bathroom walls and did some research into how best to do a door opening. I decided to use a 'standard' 30 inch door, or 762mm. This means that sourcing the door lining and door is fairly straight forward. So I went out and bought a door lining and then when I got back home I tried to figure out how deep I needed it to be, and also how tall I needed it to be. The width is fixed at 762, or probably a bit more I guess, I'm not sure how much more as I don't remember measuring it, although I'm sure I will have done just to avoid the disaster scenario.
HEIGHT
So, standard door height is 1981mm (78 inches or 6.5 feet) so I had to think about my floor build up in order to calculate the height that the door liner needed to be cut to. My floor was probably going to be 5mm underlay + 12mm laminate. So I added those together to get 17mm (so far so good) and then added a random fudge factor to give me some door clearance underneath. I probably looked this up, and I can't remember the number I got, but maybe 10mm? Anyway, I added the 27mm or whatever to the door height, and then cut the liner to what I assume was about 2008mm, but I honestly don't remember.
When I come to fit the door we will see if my calculations were sensible or not.
DEPTH
Basically set the depth of the liner to your wall thickness, plus a bit for plastering. When they plaster the walls, they need a small lip to plaster up to and give you a neat '90 degree' finish. I went for 3mm each side which meant the liner was 6mm deeper than the thickness of the wall. So liner was probably 98mm if my timber is 92mm, but I honestly can't remember. I ripped this down with the circular saw and the guide fence thing that projects from the side of the saw. I think I ended up taking off about 5 or 10mm.
Tip
When fitting the door liner, I strongly recommend connecting together the bottom of the two verticals with a piece of timber - this would keep it fixed at exactly the 762 or whatever it is supposed to be. The top is restrained by some rebates that set the verticals at the correct width, but the bottom isn't. If these are out by even 1 or 2mm, it will show as a taper against your door edge when its fitted. Although I suppose you could plane the door down. I suspect I will need to plane my door down a bit, as I notice one or two mm difference from top to bottom in my frame / liner, even though I fixed the bottom like I just described. So maybe don't listen to me...
Build it vertical
Note that when it comes to putting up internal walls, you cannot build them flat, because you won't be able to rotate the wall up into position without fouling the ceiling. This makes it a bit trickier to build the door opening stuff.
from workshop side
from office side
without door liner
with door liner (and children)
Mistakes
If I was doing this again, I would probably build the wall with enough space for the liner PLUS 10mm. Then when I installed the liner I would install it into the opening using spacers / wedges to get it perfectly plumb and with consistent 762 width from top to bottom (or whatever that width is!). I am sure if you look it up on youtube they will probably do it something like that and not the way I did it with the opening the exact same size to accept the liner. I should go and look that up now.
Desk planning
At this point we had the electrician round to do first fix and I had to do some impromptu planning / decision making for the lighting placement. It was only of importance for the area above the desk, because my wife is a math's tutor and does a lot of stuff with whiteboards and cameras over zoom. For this reason, the lighting is quite tricky to get right - not enough light and you can't see what's being written, but too much or more importantly badly positioned light and you get glare (specular highlights) from the light bouncing back into the camera and/or also shadows cast by your hand as you write. So with shadows and specular highlights to contend with the only option (in my mind) was to setup a mock desk, and get the laptop fired up in a virtual zoom meeting and play with the light placement and see which position worked best.
The conclusion from this research was that all lighting positions are terrible and therefore she will need to work in complete darkness. Seriously though, it was very challenging to find a good lighting solution, and what we settled on was a large 1200mm x 300mm light panel, situated slightly behind the chair position. Oh yeah, and that will also be on a dimmer circuit so it can be controlled quite accurately. The backup option if all this planning doesn't work out is to use the 'desk lamp' setup which she is currently using (this works ok but it isn't optimised).
desk planning
I also did some 'very important' TV planning at this stage to try and figure out what size to buy, and also what type of speaker setup to go for (in wall, on wall, bookshelf, tower, soundbar etc.). That is probably getting a little off topic for this audience however, so perhaps I won't go into the details for that unless somebody is interested in which case I am happy to cover it. Not that I know much about that stuff - just enough to make decisions.
TV planning
Martin
