Molynoox
I thought I would do a thread for my garden room build in case anybody is interested in the details.
I spent a huge amount of time researching everything and have learned a lot along the way and I figured that if this knowledge is useful to me then perhaps it could be useful to other's.
I have gained some good insights from people on this forum so hope I can contribute something back to the community.
I am over halfway through the build now, but will take it from the start so you can see every stage.
Although the primary goal is to share the knowledge with others in the same boat, I am also looking to receive your constructive feedback so that I can learn from my mistakes. So please feel free to comment, even if it is a criticism.
I will start with the plan:
its all fairly predictable stuff I'm afraid :-D
I will attach some pics of the plan and then in the next post I will start with the first stage of the build.
Martin
- 9m x 4m external dimensions
- 30 m2 internal area (to keep it exempt from building regs, although it isn't that simple)
- under 2.5m height (to keep it within permitted development and not need planning permission, although it isn't that simple)
- wooden frame (5 x 2), PIR insulation (100mm all round), cement board sheething on 3 of the external sides
- vented cold roof
- alu doors and windows
- metal header (flitch beam) above bi-fold, timber header above french door
- EPDM roof
- battens and cedar cladding
- vapour bariers inside and out
- bathroom (water and waste)
- power and internet
- groundscrew foundations
- heat pump air con for heating and cooling
- composite deck
- cedar pergola (partly for shade, partly a privacy thing, for both us and the neighbours)
Martin
