mikefab":3ng6inl5 said:Nice job!
It would be interesting to know which hand tools you used? And what is the purpose of the hole in it, or is it merely decorative?
phil.p":fyt6ozl1 said:Just don't let vinegar or lemon juice near it.
phil.p":2fhg6bia said:^^^^ yes, it stains blue black. Incidentally, mentioning washers much as I dislike Jamie Oliver the best bit of advice I got from one of his progs. was to buy plastic chopping boards small enough to go in washer. I regularly use three or four at a time - no contamination if you're mixing raw and cooked.
phil.p":16uiwd1j said:"Erm.. that is not true. It is mandatory in catering to have colour coded boards for different food groups to help prevent cross contamination. They also should be replaced once badly scored. If you put cooked meat on top of raw meat juice then the surface you are using won't make that cooked meat safe. Polypropylene cannot prevent cross contamination, only good food handling can."
I spent my working life in catering, I know the laws. I'm not sure of your point - I use one board for one foodstuff, another for another and maybe another for another, then chuck them in the machine. That's the purpose of using three or four boards. That was exactly my point.
