PeteG
This isn't a review as such, just a few piccies of my new scroll saw, a Sealey SM1302, and my first test piece.
And here is the little beauty
variable speed, 120W motor, throat depth is 406mm, maximum cut is 50mm and the stroke is 15mm.
It took me a couple of days to realise that the lever at the back not only releases tension, but if you turn it before locking, it increases blade tension.
Blade change is very easy with pinned and pin less, here's a few images of above and below.
The left hand blade was the one supplied, on the right is a number 7H 15 tpi from Hobbies.
My first test piece, probably a little too ambitious
but I had great fun. The blades I ordered from Hobbies took a week to turn up, so I used the supplied pinned blade. The plywood was a scrap piece, 1/2", and not very good quality, the veneer was quite thin and prone to peeling, but there again the blade may not have helped. Not sure how long it took me, at least a couple of hours, I was standing so the back ached like a goodun after wards. Will need to sort a chair out once the shed is a little more oragnised, and better glasses
I nearly forgot
I'd like to thank Jonluv for all his help and advice
Thank you John, I'm a happy man.
![](https://proxy.imagearchive.com/b3b/b3b90a28776e2224c198293260a7e23b.jpg)
![](https://proxy.imagearchive.com/5c4/5c4e109490d5faf97f003d1582593409.jpg)
![](https://proxy.imagearchive.com/f97/f973cd466ce2ab334006124b027b41c0.jpg)
![](https://proxy.imagearchive.com/066/0668b38b46ca2e42f9380385de87c1d8.jpg)
![](https://proxy.imagearchive.com/420/42036e84e8379c6ca7505047b3f1a5c6.jpg)
![](https://proxy.imagearchive.com/5f7/5f799108c92f44d862803a5191110318.jpg)
I nearly forgot
