A
Anonymous
Guest
Hey everyone
Does anyone use one of those electric or air nail guns? today I purchased the Rapasco heavy duty nail/stapler which Argos had at £7 cheaper than Axminster.
The build quality is fantastic, its only plastic but its such a good quality plastic that at first I thought it was metal as it was so rigid, however as for the performance thats another story.
I loaded it up with the supplied nails & if you watch the new yankee workshop when Norm uses his air nailer you will know that he just holds the workpieces together using a clamp & with one hand just nails it in one easy push of the trigger, not so with this gun, the nail was left sticking out of the wood by about 3mm :roll:
With the other hand I tried a little pressure on the next try & sure enough it drove the nail into the wood perfectly flush, but there was severe marking on the wood even with the little plastic nose attached which is supposed to prevent any damage to the wood, whatever I tried it was a real hit & miss type of thing with either the nail not being driven into the wood properly or driven in with so much force that the plunging mechanism on the nail gun had totally damaged the wood with nasty 1 or 2mm deep marks.
Im taking it back tommorow for a refund as im not happy with the performance of this machine, im thinking an air powered version which has adjustable pressure may be a better buy.
Any thoughts or comments on this sort of thing? & does anyone own a air powered nail gun? if so are they any good?.
Thx & I will be doing a review of my new Sheppach HMS260 very shortly, Charlie is in the process of uploading the first review I have done on the Record DX5000 extractor so hopefully it should help people when choosing new equipment if they can read some reviews here.
Nick
Nick
