DBT85
I'd make a dolly you can shove under it. 80kg is only really 40kg to lift as you'd only lift one side at a time and a 40kg deadlift with a foot nudge to move the dolly should be doable for just about any adult without other conditions. Even if you only got the dolly under one side, a 40kg lift and steer should be OK.
That way you can move it easy enough and pop it back down again.
Plus the dolly can be used for other things when not moving your saw around 3 times a year.
Natually remember that if you want to raise one side up by 100mm, lift the other side up by 50mm and nudge something under it first. Can be done repeatedly if needed.
