Hi All
I am cutting a through mortice for a wedged tenon.
I have predrilled the bulk out with a hand drill and am finishing with
a bevel edged chisel.
I was worried about drilling too close to the knife line so I have prob left too much material (about 4mm)
It is my first time cutting mortices and I am not sure if I am doing it correctly.
1. Do I try to chop the remaining material out by placing my chisel in the knife line and using a mallet?
I have been doing this but it seems to take so much force and I am not sure if my nice LN chisels were meant for such heavy hitting!
2. Do I just take smaller "bites" out of the waste say 1mm at a time and work back to my knife line?
3. Should I need a mallet or should I be able to par back gently to the knife line if the chisel is sharp enough?
The LN chisels come ground to 30deg, I have put a secondary bevel at 35deg and then polished at a further 2deg using a vertias II jig.
thanks for the help
Andy
thanks for the help
Andy
