Fraseman999
Hi Folks,
I have a new jet 701 morticer which should have plenty power. I have purchased some chisels for it, not good quality ones. I have set the clearance correctly and to be honest i am very disappointed. I cannot stop the chisel from burning. The 701 comes with clearance shims and certainly has the power. I have resorted to using a normal auger bit and it cuts through like butter, then using the mortice chisel bit to square the sides. Can anyone tell me what my problem could be. I can only assume that if i have spent £20 on a set of chisels when a good one can cost £100 then it must be the bits. If i use the chisel/bit it takes an age or my bench would go on fire! when i do it with say the 16mm auger i can put the chisel bit back in and clean up and it takes half the time!
Any ideas?
fraseman
Any ideas?
fraseman
