Some more turnings. Hopefully I should get my lathe back tomorrow and get some more done...
(all photos are clickable for larger versions)
Spalted beech fruit bowl with lemon oil finish.
30cm diameter, 5cm high
Burr oak dish. Finished with Chestnut Finishing Oil
20cm diameter
Rippled ash dish. Finished with Chestnut Finishing Oil
31cm diameter, 6cm high
Elm dishes. Finished with Chestnut Finishing Oil
31cm diameter, 7cm high (large one)
This was my first use of the Sorby slicer for bowl coring and I'm now really pleased that I bought it. It may only let you get cone cores but it's the cheapest corer and is better than nothing. I could have got a deeper core but played it safe this time.
Burr elm bowls. Finished with Chestnut Finishing Oil
~23cm diameter, ~8cm high
My second use of the Sorby slicer. I had 3 elm burrs and hated the idea of wasting the middles of them so I bought the slicer. I've put of turning any off the burrs for fear of making a mess of them so I waited until I thought I had enough experience.
Unfortunately the bark was loose in a couple of places but very firmly attached in others so the larger bowl has some areas with and some without and because of the areas without I left the walls quite chunky. I'd read and seen that one suggested thing to do when this happens was to scorch the bark and missing areas so it wasn't quite so obvious, and I tested this on the core. It kind of works but I'm not convinced by it so didn't do that on the larger piece.
Duncan
