Bodrighy
If you've got holes the wood worm has flown. An old cabinet maker told me that 9 times out of 10 if you can see the holes then the damage is done. The problem is in the destruction that has been caused as they mine their way out. If you are turning and the damage is too bad it simply falls apart on you. So far the only time this has happened to me was with a reclaimed mahogany door frame which went to powder once I got past the first 1/2" of wood when turning. I wouldn't store wormy wood with other wood knowingly but if it's being turned then you shopuld be safe.
I'm sure someone will come along with either a better explanation or a rebuttal. :lol:
