skeetstar
Folks, I've been asked to make one of these
for my grand daughter. It is a climbing frame as shown, but when turned over and filled with cushions it make a sort of rocking chair. The cross pieces will be Oak rods, but I need a bit of advice re the semi circular side bits.
Plywood would be an easy option, but Id worry about the edges splintering, esp is rocking chair mode.
MDF would similarly be easy enough, but would the edges hold up to use and abuse?
I could at a stretch use flat boards and glue up in a laminate arrangement to make the sides out of soft wood. Never done this before, but cant be that hard..?
I plan to rough out the shapes with a jigsaw then mill to final shape with a router.. doe this sound like the way to go.
As usual, thanks in advance.
