It looks like I'm going to be moving across to wales temporarily, This means leaving my workshop behind, with all the inconvenience that entails.
I'm looking at options for having a bench with me; ideally one I can store out of the way as i'm not sure I can find accomodation with a dedicated workspace.
I've been given a workmate, which fits the bill perfectly apart from how insubstantial it is on its own... One possibility is making some brackets from steel angle and bolting it to a thick MDF base, it wont be as quick to set up, but it would add some much needed stability (especially if the base was big enough that my weight was on it too)
The other option is to go back to the trestle Idea I had when i was looking at making a knock-down assembly table (fortunately before I finalised a plan work decided to scrap one of theirs, so I saved it from being chopped up)
If anyone has other suggestions, they'd be welcome, I'm happy to build something; but I don't know how I can combine sturdy and compact well.
I suppose I could make a small "school type" bench using bridle joints and bolts so it could be knocked down into two frames, crossmembers and the top... but that would be perhaps too faffy.
