AJB Temple
Finely figured
I intended to install a pellet burner for heating my new kitchen (presently in an outbuilding that I will connect to the house). I am having second thoughts and may use large vertical radiators as elsewhere in the house (I have replaced practically everything) like this:
I don't do central heating plumbing myself, so had a chat with my regular plumber. It is a 35 metre run each way through roof spaces to get to the furthest possible radiator point in order to connect back to 26mm copper from the external boiler (which terminates in the airing cupboard where there is a Megaflow system.) The boiler is due for replacement and will be resized to suit the full system and any likely additions.
All current plumbing is soldered copper, but because I have to do a 5 metre span for a connecting room that is not built yet, the plumber has suggested MLCP, either Imeti or Gerpex. I had never heard of multi layer composite pipe before. He reckons it is better than push fit, but requires special tooling (which he has). The pipe comes in insulated and uninsulated form. I would use insulated, largely because of the unbuilt span.
I am two minds about this, partly because it ties me to a plumber who has the tooling system (£2k he says), which I think may be tied to the pipe manufacturer as well. He is suggesting Gerpex or Imeti. We would still use soldered copper to connect to the rad valves.
Does anyone have any experience of MLCP? At present I have no idea of cost.
