neilyweely
A short warning, although I am sure most here are far more safety conscious than I.
Yesterday evening I was planing a bevel on some bamboo flooring in order to use them as thresholds. I needed a shallow bevel and the fence only went to 45' so I set the guard across the blade and was using a strip of wood stuck to the CI top to hitch the bamboo up to the required angle. Stupid, yep.
After five minutes of success i got a bit complacent, and realised I wasn't paying enough attention so redoubled my efforts.
Then Mrs Neilyweely asked if I wanted tea and quick as a flash my two biggest fingers on my left hand swiped through the exposed bit of blade, cutting a centrimetre off the middle and 5mm off the one nearest my thumb. I looked down and, well I guess most of us know the feeling, I knew it was bad. My Mrs couldn't find the micropore and the football was about to start, so I rang my pal, who is a GP and askeed what to do. He said there was unlikely to be much the hospital could do as it is very diificult to sew a tip back on, and I should line it up and tape it back on. Job done, and although it hurts like bug*ery I am working again today. However the truth is I am VERY lucky not to have lost both fingers or even a hand.
T'was a blunt blade on an old Myford, causing some vibrations. Complacency really. And reluctance to spend time changing the blades. But I believe if the blades had been sharp and cutting without vibrations I would've been OK. Of course if i wasn't so stoopid I would've been OK.
I will NEVER use a planer without a push stick again. Shame it took this to force that message home. Perhaps you could all learn from my stupidity.
HTH
Neil
HTH
Neil
