The predefined stops need some more looking at but they didn't give me a huge amount of joy at first glance. I released the bevel stop lock so the saw head moved freely from side to side and locked it down with the blade at 90 degrees to the table:
I then attached a magnetic angle finder and zeroed it
I re-engaged the bevel stop lock and tried moving it from left to right and seeing whether the digital doo-da returned to 0. It turned out that if you entered the 90 degree stop raising the saw from the left you'd be dead on. Raising the saw from the other side locked it consistently 0.3 degrees out. Not good but I can live with that I supposed. It'll need an eye keeping on it before any trust relationship gets built I thought!
I then carried on to check out the other positive bevel positive stops: 22.5, 33.9 and 45:
Not what I'd call outstanding results! Thinking about it now, I didn't have the saw clamped down to the bench so there's a chance of the shifting weight influencing things. Anyroad, I decided to leave the bevel stops there until I see how to tweak the stops... assuming you can... and likely resort to setting them manually or making some jigs when I'm bored.
This thing has lasers and a LED light. I marked up a piece of scrap with 2 lines at 90 degrees and stuck it up against the fence
Looks good to me! Nothing is ever quite perfect though as the 2 black roller wheels on the blade guard block out sections of the lasers as it raises up. I'll wait and see where the lasers point at and where the kerf actually goes at a later date. They are adjustable too and I brought the right laser just a hair closer to the blade to prove it. I'd still say I prefer the Dewalt XPS lighting (and now on the KS60 I believe) however as it doesn't need calibrating, works automatically with differing kerfs and isn't obscured by anything although you do have to drop the blade down nearer the wood to see it.
By this time the fingers were about to start snapping with the cold so I had only a quick look at the sliding fence wizardry. With the positive stops engaged I swung it into the 90 degree position and stuck in my square. Nice.
As of the time of writing I haven't actually cut anything with it yet! I have a 36mm hose enroute so I'm waiting for it to arrive before seeing what the DC is like. Tomorrow hopefully!
