Plus a Kreg system no probs. what ever angle you want. =D>Digit":2lu2d1yk said:Or a table saw! :lol:
Roy.
Paul Chapman":nxl4lu5b said:One of the best shooting boards I've seen is the one made by Pete (Newt). You can shoot most things with that one
Cheers :wink:
Paul
Hi its an Hitachi mitre saw that i have i wish i never bought it to be honest i think i would have been better off with a good second hand ras but you live and learn!tomatwark":35lg4l9v said:The one question that has not been asked is what make of mitre saw the OP has.
If it is one of the cheaper ones it will never be accurate.
Also if it has bounced around in the back of a van on and off site it will probably be out.
If you have a good quality saw which has not been abused it is possible, but even then there will be some fiddling around to get the set up right and it is often quicker to cut them somewhere near and adjust them by hand, unless you have a saw bench which is set upright.
I am lucky to have a panel saw which is spot square and the length spots a correct, but I still always check the angle when I tilt the blade because even a small build up of dust in the saw can stop the blade tilting to fully 45 degrees and prevent the mitres being accurate enough for boxes.
Once set I can knock them out on the saw, but if it is just one box it is often quicker to adjust them by hand.
A slightest gap will show especially on light woods such as Sycamore or Maple.
As has already been said mitres are difficult.
Tom
Ever tried one? On an ordinary shoot it's the best plane I've ever used, far better even than a LN No9. If you're going to the AxBash in a few weeks you might be able to try one and then the penny will drop :wink: :lol: - RobRogerP":3tzx5adl said:With the K G Wells type board where the plane is held at 45 degrees the expensive wonky handled Lie Nielsen No. 51 Shooting Board Plane is redundant.
woodbloke":14kdh2p8 said:Ever tried one? On an ordinary shoot it's the best plane I've ever used, far better even than a LN No9. If you're going to the AxBash in a few weeks you might be able to try one and then the penny will drop - Rob
There's a left handed version in the pipeline :wink: - Robkatellwood":3cos77qc said:woodbloke":3cos77qc said:Ever tried one? On an ordinary shoot it's the best plane I've ever used, far better even than a LN No9. If you're going to the AxBash in a few weeks you might be able to try one and then the penny will drop - Rob
But what if you're left handed, were discriminated against again
woodbloke":1amnxppr said:Ever tried one? On an ordinary shoot it's the best plane I've ever used, far better even than a LN No9. If you're going to the AxBash in a few weeks you might be able to try one and then the penny will drop :wink: :lol: - RobRogerP":1amnxppr said:With the K G Wells type board where the plane is held at 45 degrees the expensive wonky handled Lie Nielsen No. 51 Shooting Board Plane is redundant.
More or less a smaller version of the one I made.Harbo":2bc57oxp said:Here's one of the longer types, but I generally use the Pete Newton version:
Rod
