loftyhermes
I think they're called Paramount walls, our 1980's built bungalow has them.
Not necessarily. I've seen fd30 doors fitted to themBut are designed for papier a mache doors.
There is no point hanging a door on an unstable wall, any remedial work will be like stacking plasters on a bad cut that really needs stitching. I always think it is better and cheaper to do a job right first time rather than having to revisit it later to repair and you will also have the freedom to alter the size and layout with new walls. As for the old plasterboard just bag it up and your local recycling centre should have a dedicated bin for it, our local one does.OK, after a week or more of 'pondering' I think I'm settling on pulling the walls down and rebuilding better stud walls.
That's exactly how I'm thinking. The walls look like a bodge to start with. Just tacking onto that is going to be a bodge on top of a bodge. I'd feel much happier in the long run about having a decent foundation to start with, even if it does mean a slightly larger outlay.
In terms getting rid of the plasterboard, ideally I'd have liked to get a skip/hippo bag, but we live on a private road where access isn't possible.
I can take to the tip in my van, but the costs to dispose are pretty hefty, so just thinking of the effective way to get rid. They'll be quite a bit coming out!
I know it is easier just to fill a skip but using small bags from screwfix NDC Polipak Mini Skip Bag 500 x 500mm just fill them neatly with smaller pieces and then take down the tip in your car boot so this cannot be classed as trade waste. A little more effort but could save some money.I can take to the tip in my van, but the costs to dispose are pretty hefty,
Would hate to think of a fire in houses made to the standards posted here fd 30 min wall 5Not necessarily. I've seen fd30 doors fitted to them
The ones in Manchester are all privatly run ie Amey etc and the will only take a small amount at a time with the mass use of drywall in past years we are heading for a problem in the future . If thepoor people who are reduced to living in cardboard boxes read this post they will think they could be worse off in modern housingThere is no point hanging a door on an unstable wall, any remedial work will be like stacking plasters on a bad cut that really needs stitching. I always think it is better and cheaper to do a job right first time rather than having to revisit it later to repair and you will also have the freedom to alter the size and layout with new walls. As for the old plasterboard just bag it up and your local recycling centre should have a dedicated bin for it, our local one does.
Yes, they are indeed fink trusses. Should be fine I imagine.I would think that if they were structural support walls then the roof would have collapsed by now so just check what type of roof trusses are fitted. They are probably finks type trusses which are just supported on the outside walls and are designed to have long spans.
Looks like you have come up with a good solution , Like the best Grand Designs hit a snag keep em fluid and think of other ways round it PS scraping PB down here costs plenty at the tip so good reuse and now just rhink if you are ever stranded on a desert island you will be able to survive in comfort just pack a few tools when you go on holiday in caseThought I’d give a little update on this. After much thought, mulling, measuring and planning, I decided not to pull down the walls.
Instead I’ve cut out the existing door frames and then added new stud work around the door opening, made new linings. The door lining run flush with the landing, but come out further into the rooms where I’ll be battening it out and fixing plasterboard, so the walls will be as thick as if they had been redone.
In the end I couldn’t bring myself to ditch all that plasterboard when it was technically useable.
These first three door linings was a bit of a test, but to be honest, they feel pretty darn solid.
Made the door linings up using an mdf template. Also reduced the width of the doors to 686mm wide doors to allow for the extra stud work. Studs fixed to plates on floor and ceiling. Had to add extra noggins in the ceiling.
Any additional space around the stud work has been filled with expanding foam.
Few more to do then to get it all skimmed.
Will try and post some more updates when I hang the doors!
