shorn
Hi,
I'm just starting out with renovating our house. It’s about 25 years old, and have realised that the internal walls are all laminated plasterboard construction. 3 sheets sandwiched, 15mm each side with 20mm inside. I’ve started looking at the door linings as was planning on replacing and hanging new solid doors. However, the current linings are about 20mm thick and only 50mm deep. Looks like it’s a moulded construction as, from what I can tell, the jam/stop isn’t separate.
Nothing available off the shelf, so I’m looking at making my own.
Question is, is a lining of 20mm thick going to be strong enough to hold a solid door?
