Inspector
Nyuck, Nyuck, Nyuck!
...and took bites out of cars that honked with the bucket and thumb!Just take the digger up the M5...
Awaits news story Cornish redneck drivers his digger up M5 in rush hour!!
Anywhere that you have junkies then everything becomes fair game because to you it may be worth thousands but to the junkie it is just another fix.We are fairly safe here in devon, but just last week a local digger went awol.... which got me thinking.
Surely not a digger?Anywhere that you have junkies then everything becomes fair game because to you it may be worth thousands but to the junkie it is just another fix.
Then they just use a lead with croc clips from the battery to the pump solenoid, if it starts and then stops this in the heat of the moment just blows there little minds because now it is not obvious as to whats wrong, could be low fuel or something and the clocks ticking so they leave.but ideally make it so it won't start at all.
I'm probably being a big thick so forgive me, but what do i need to make the oil pressure switch setup work? Or is it simply a toggle switch interrupting the wire for the oil pressure switch?Then they just use a lead with croc clips from the battery to the pump solenoid, if it starts and then stops this in the heat of the moment just blows there little minds because now it is not obvious as to whats wrong, could be low fuel or something and the clocks ticking so they leave.
No, especially since i havent declared my new purchase!!You caint keep it at home??
