Micro Butane Torch
Nigel Taylor
18 Oct 2020
UK
Just bought one of these small butane torches. I always thought they were a gimic, but this works really well. OK, best for model engineering, but using this with silver solder paste for silver soldering small items is superb.
I recently replaced mine. Didn't know when I bought the first one how much it would come in handy. I then bought a 'bong' lighter which is similar but much cheaper. I use that one to get the fire started in the stove. I don't use bongs by the way.
A quick tip re those micro torches. Don't know if it's still true/applies in UK, but I bought one yeas ago (and very good they are for small jobs, inc soft soldering). I bought mine in a tool shop or at a model show, I forget now, but it was less than half the price of one appearing a while later - exactly the same mind - in a cooking shop.
That's not a micro micro torch thats a large size this is a mico torch brought one years ago not expecting it to be of much use is was so cheap but it's come in handy for a few jobs over the years always have to fefill from a lighter gas can before use as gas slowly leaksbut otherwise fine.
    26.6 KB
I borrow the one from the kitchen. I use it all the time for getting heat into inaccessible places, bearings and seized bolts, also soldering larger items where my soldering iron can't cope. I must get my own one.
My kitchen one is quite a bit larger than that, flame is probably 10mm across, great for the BBQ and fire lighting but not one for small jobs. Just a heads up in case ordering online and the size is not clear.
Just been silver soldering the parts for the rear hub caps and thought I would share the process of using easy flo paste, very easy to get great results on small parts using this paste and the micro butane torch
