Saint Simon":bvbxlg9w said:
When using a sharpening system, like the Veritas, that allows the application of a micro-bevel, what happens the next time you sharpen the tool? Do you sharpen to the basic angle taking off the m-b and then reapply it or do you just apply the micro bevel again, leading to a larger and larger m-b? The former seems hard work and a waste of tool steel and the latter makes me wonder why have a basic angle at all. Help please.
Half way between the two (as you observe, the two extremes are poor).
The purpose of the primary bevel is to keep the secondary (Veritas call it micro) bevel small. It does not form the cutting edge.
As such, it can be worked with coarser abrasives.
The primary bevel should never be worked until it meets the cutting edge, since this removes valuable tool steel, and shortens the working life of your tool.
Honing of the actual edge is done on the micro bevel - since this is small it can be worked rapidly, even with fine abrasives, leading to a fast sharpening system.
In fact it is not even neccessary to work the primary bevel every time you sharpen, speeding things futher.
Some people prefer a triple bevel system, where there is a primary (or relief) bevel, worked with very coarse abrasives (or even a grinder), a secondary bevel (quite) small, and a third bevel (micro bevel?).
In this approach, the secondary bevel is worked all the way to the edge (but ONLY to the edge), using a "medium" abrasive, and a tiny microbevel formed afresh at each sharpening.
BugBear
