MFT top with the RS CNC jig
This might be a real ignorance on my part but I am struggling to see what an MFT does or how it is used
I have a bench with a row of dog holes, an end and front vice and that holds everything
Ian
Ian
Because the grid of holes are perfectly square, it allows you to align boards and track saws at perfect right angles, allowing accurate cross cutting, as one example.
Your bench can do everything else an MFT can, hold downs, etc.
Sent from my SM-G973F using Tapatalk
And I thought you were trying to make perfectly round concentric circles. (hammer)
I think I would need to see it in use to really get it
Ian
Thanks Sammy and Steve for the links and explanations and you tube links.
Im not really getting it but then I would use the panel saw rather than a track saw
Thanks again Ian
