MFT style cutting / assembly bench
DiscoStu
24 Mar 2014
Lee on the Solent
I am looking to build an MFT style cutting / assembly bench.
In my head it will be around 1200mm wide and 800mm deep so that I can make drawer slides for systainers on both sides. I will use Parf docs on the top to give me perfect square cuts with my Ts55.
I am thinking that I will install T track along the top of the front edge so that I can clamp to that.
I am also wondering about installing some T track in the MFT top so that I can use a stop in it for repeat cuts. I've looked at a lot of videos etc and I've never seen anyone so this so I'm wondering if I'm missing something, if it's not needed or if I just happen to have had a good idea (highly unlikely).
The whole thing will be on wheels for ease of use in my workshop.
I'll mainly be using it with a hose and power lead coming from above so I don't think I need to worry about hose rests etc.
Anything else I should be thinking about or consider adding?
How hight would you go?
Is there any point in adding folding extensions to the ends?
Yes that will be a good idea.
That could be useful or you could just clamp a batten in place as a stop when required.
You could consider at this stage if you wanted to make a sacrificial kerf strip in your table so it can be replaced when needed. Or just live with a permanent kerf cut in your table (no bad thing really).
I think the MFT is around 900mm high but obviously you have the choice of making the height which is most suitable/comfortable for you.
Could be useful for longer work pieces, but not essential in my opinion and could probably be added on at a later date if you feel it is required.
I would also suggest you invest in at least a couple of lever clamps.
They don't have to be Festool one's as there are similar one's available from Axminster etc.
http://www.powertool-supplies.co.uk/fes ... 0wodGFYMAA
http://www.axminster.co.uk/axminster-tr ... amp-505561
I don't understand why you're putting in a T Track for clamping? The whole point is the clamping holes all over it. You will saw through it at some point, mark my words.
Don't buy the Axminster clamps, I have some and never use them on the table, they're too fiddly to get through the holes in the top as you have to fully open them before you can angle them through, just a faff. Hard to explain, but I speak from experience.
Cough up and pay for the longer Festool screw clamps 489571 and then get some of the clamping elements 488030. You've got all bases covered for clamping then.
Oh crikey Wuffles has made a good point about the Axminster clamps that I hadn't realised.
I have the Festool clamps which are 160mm capacity and the Axminster one's are only 120mm, I thought they would be a cheaper alternative to Festool but I can see are not the same length and 120mm could cause problems when feeding through the holes in the table.
So did I have the 160mm ones, sold them to someone when I flogged my old TS55 and regretted it immediately :)
The longer ones are not much more money and awesome. And by awesome, I mean
<fireworks, loud PA system, monster trucks> A W E S O M E </USA>
Well, they're not, but you get the gist.
Very good point Discostu!
We produce an mft style top 800mm x 1200mm in mr-mdf for our installers out on site which they just pop on stools and clamp down. They fit a t-track along the edge for fast clamping and alignment. May not make sense but put into practice it is a good system.
The main reason they don't machine it flush is because they just sit on stools and t-track is 12mm or 15mm (the ones we use) so does not leave suitable support in the 18mm thick board. (over 18mm festool clamps wont fit through hole due to angle)
If it was built into a bench though there is no reason it cant be set flush.
Your thinking is spot on and is very handy and fast in practice but to some may seem pointless. The t-track we us fits the festool clamps as well so gives any adjustment over the set 96mm x 96mm dog spacing's.
Im in the office at the moment but will be over in the machine shop in a minute and will try post a picture of one as usually a handful laying around the warehouse.
Wolfey.
Thanks for the replies guys.
Just to clarify I already have both Festool and the Axminster clamps so I can try both. They look identical to me (from memory) but I've not tried them in a top.
I was aware that 18mm was the maximum thickness but it's an excellent point to anyone else reading this.
My intention is to build a frame around the MFT top to embed the t track in and also to allow a top to be easily replaced.
Wuffles your point about cutting through the t track in the top is my concern and roughcut's suggestion of just clamping a batten in place is simpler and probably more sensible.
I am also thinking that I might put a t track on the front of the unit but going vertically so that I can have a simple screw block in there that will support the weight of any heavy pieces that I might be working on the edge of. (Rather than just relying on the clamps in the horizontal t track)
I was looking earlier and I think I might end up with a bench similar to Peter Parfit's mobile bench, just with addition of drawers for systainers on both sides.
You haven't then, because the ones I'm recommending look nothing like the Axminster ones.
The last picture shows one in buffalo board as we have a team on external works at the moment so handy when it rains.
    204.5 KB
    200 KB
    205.7 KB
    235.4 KB
Really interesting topic this as I've pretty much decided to replace my TS out feed table with an mft style top as I use it as a work bench/assembly table/finishing zone plus the out feed duties lol.
Something I saw recently was a router bit for cutting grooves like t track but in wood, this could be useful as if you made effectively hardwood t track (instead of metal) then it would avoid the worry about sawing through them.
What do you guys think? I'll post about my designs when I get around to it lol
Here's mine ,works great with the Dewalt horses as they're so solid.
Since I built it it's been so handy for everything when I'm working in people's houses.
Sent from my ALE-L21 using Tapatalk
Adam9453 I think you have nailed it!!!!
That would be a fantastic idea to overcome the issue, be it a simple 2x1 hardwood section run around the edge or if built into a bench a 3x2 section with an 18mm rebate for the board to sit in and easy replacement.
Would use something hard like Maple for the frame/track .
May get the lads to try this out on one of our 8x4 assembly benches..
Wolfey
This is the clamp that I have and was referring to:
This is the Festool version which I also have and appears to be the same:
And look again at the part number I referenced in my post?
Here's the link to the router cutter I was referring to;
http://www.axminster.co.uk/axcaliber-te ... ccessories
think I'm gonna go down the route I proposed. Ie hardwood strips mounted flush into tables with the t slot routed into them. I'm probably gonna get some of those festool ratchet clamps disco stu showed as they should make nice quick clamps that can slide backwards and forwards in the t slots.
I think I'm gonna have two slots running toward me and two slots running left to right (when standing in front of the longest side of the table).
Combine that with some mft style holes and clamping worries should be a thing of the past
I've looked at lots of different ones. Just interested to hear people's thoughts and views. Any advice on castors?
Hi Stu,
Just to resurrect an old thread, did you build your table in the end, how did it turn out?
I'm planning to start mine soon as getting tired of the wasted space under my current out feed table.
Ummmmmm, ummmmmm
That would be a no, not yet! Still intending to. I got stuck into other projects. I did buy the Parf guide system for making my holes but even that is still in the wrapper.
I really must crack on with it. Trouble is the weather is now cold and I don't have much space to build something of this size inside my workshop. I normally wheel my table saw out and some saw horses for bigger projects.
