brucew
I've been using a slab of 18mm hardwood plywood as a worktop with a friction fit down onto a pair sawhorses. There are a few 20mm holes for track saw use and when I clamp a piece down to it, I use F-clamps on the edge more often than not. But of course this single slab is no longer absolutley flat with a *very* slight camber to it (1mm or so) but still rather functional, so was thinking about torsion boxes to maintain the flatness.
The classic torsion box seemed to be made with several cross braces to make a number of "boxes", but an MFT makes use of lot's of 20mm holes for work handling and so those tend to be a single box the same dimensions as the top slab (no overhanging lip). What I'm wondering is why not do a box that is a bit smaller than the top slab and leave a lip for easy edge clamping? The ones I see require clamps at least 6" longer than otherwise.
I didn't post it in the other convo on torsion boxes as it's become mired in arguments mostly unrelated to my question.
