I'm almost at the stage of completing the framing on my new workshop build and now considering roofing.
I was intending on using Marley fibre slates, having already purchased the roofing battens, but having working out the costing of everything involved, it would be alot cheaper and easier to install 0.7m Plastisol covered metal sheeting (40yr life apparently). As the build is not visible to anyone, aesthetics are not an issue.
Q1. One thing I'm not too sure about is loft ventilation. I'm guessing the metal sheets should be installed over a solid decking (18mm OSB3) and as I intend to have a proper ceiling, the loft space would be fully enclosed. How do I deal with the ventilation? Does it need it? Would soffit vents be sufficient?
Q2. What is the correct membrane to use in between the sheets and the OSB3? Is a regular Tyvek breather membrane OK, or should it be something else?
Membrane spec and ventilation issues aside, any other reason that metal sheeting would be a bad choice over man-made slating?
Cheers guys.
Cheers guys.
