metal fitting's with allen head's
A
Anonymous
Guest
Does anyone know where I could get metal fittings where its in 2 halves (like a saw nut), with hex allen heads to tighten up, like you get on some flat pack furnitures?
Cheers Mr S
Thank you for your replies gentlemen
The ideal solutiuon I think would be the M6 screwfix cross head bolt's matched up with an adonized(??) steel version of the brass head M6 nut if it's possible to get them (screwfix dont seem to). I need the wide 15mm surface area and would prefer the extra strength of steel over brass. The carcass joiner's won't be sufficeintly strong, or wide enough on their flanges. I even had one or 2 snap when I have fitted K unit's before. Am I right in thinkung that the screfix nut insert has a hex socket for a part of the depth and is M6 threaded below that and has to be fitted into a pre drilled pilot hole? The only thing I dont like is that it looks as if it would be in place permanently.
Thanks agian for your helpful tips
cheers Mr S :D
Screwfix do sell the allen key steel cross dowel bolts, steel with zinc plating.
Look for the cross dowel bolts, half way down this page
