kenneth cooke
I have now tried the blade which Dragon Saws in Wales sent me (5/8") cutting a piece 2mm thick from an oak block 150mm x 1m x55mm. The cut was uniform throughout requiring some planning with a No 7 Try Plane.
How does this blade compare to the other I have used, namely a blade of the same dimensions from Hamilton Edge Tools also in Wales?
Very comparable but supply of the Dragon Saws blade was much easier. They offered to supply a blade on the Friday. It was delivered Tuesday and prices were very similar.
It is my view that if one wishes to accurately slice hardwoods to plane-able dimensions then Meat and Fish blades are the answer. But machine set up is of paramount importance. A subsidiary re-saw fence needs to be made and fitted. Tension is not critical but accurately set guides are in order to produce repeatable good results. And finally listen to your machine and feed accordingly. Don't choke the cut and try to make the whole cut one continuous smooth operation
