MDF Quality
Geoff_S
12 Sep 2017
London
I have generally bought my MDF from a well know local timber yard for years now. However, I have noticed recently that
when ploughing a properly sharp router bit through it, it seems to be very fibrous resulting in quite a lot of sanding to
smooth the cut off.
So, I know a bit about HDF, but are there better quality grades of MDF and if so, where can I get it?
My local timber place sells the premium Medite stuff. Try asking for that. Seems ok for MDF to me, I try to stick to plywood for casework- just built some workshop cabinets with some okish hardwood ply and it is nicer to deal with than MDF IMO.
Sent from my iPad using Tapatalk
thick_mike":1yicc3k4 said:
MRMDF is much denser with a less fluffy core. Machines well.
+1 Best I have used is Medite V313 MRMDF then some other MRMDF but not sure of the manufacturer. I won't use the beige B&Q stuff if I can avoid it because it is so fluffy on the edge. My supplier (Laver online) is not too pricy either.
Moisture Resistant MDF is better for routing than regular MDF, but you can do better still.
A few of the MDF manufacturers offer variants of MDF specifically designed for routing and moulding work, for example you could try Kronospan Deep Rout which is available from quite a few outlets including Timbmet,
http://www.timbmet.com/uk/products/range/mdf/mdf-range/
It gives a very smooth and paint ready surface straight from the router.
Good luck!
I got hold of a few offcuts recently that were interesting. A green tinged moisture resistant MDF was like everyone else says noticeably tougher on the surface and less furry when cut.
Also, what i figure was Valchromat or an equivalent. Harder still, very impact resistant, very clean cutting. The dust had an abrasive, fine but granular feel to it. I put it to use as a small benchtop and as wear / impact facings for something that gets a lot of knocks. Valchromat is pretty expensive but Axminster do MFT style tops out of it and I think it might be good for that purpose.
