Thanks for the advice - top and bottom panels removed and replaced with fresh panels screwed and glued. Pilot holes drilled as Studders suggested.
I did think of using traditional housing but was worried about getting decent cuts on this crappy MDF?
I also did a dry assembly on some of the panels with no problems so the glue must have caused the problems - I did drill them a few mm longer than required. I also think the Srewfix dowels are on the "large" size as they are a very tight fit in the Joint Genie jig holes?
Still will not make the same mistake again?
Thanks.
Rod
Thanks.
Rod
