LyNx":3nsljd51 said:Tony. Must stop asking questions so you can get out and use it :wink:
Is your pics only showing the single side extension then?
murphy":2huu4zri said:Thank you for your reply, but when I turn the tilt wheel the rise and fall wheel moves as well so the pointer is always behind it and can only be seen at an angle, I have got in touch with Axminster and they said that is the way it is made, I have bought a GemRed Digital Angle Gauge which has solved the problem, it is very accurate, as I will be doing segmented turning accuracy is a must.
Pat
