Mark A
Hi I've bought the Makita plunge saw a couple of months ago with the 48 tooth blade supplied with it but I need a blade more suitable for ripping. Makita make a 28 tooth blade which is ok but it's £27 - £30. The makita blades blades are 165mm x 20mm bore with a 2.2mm kerf. I was thinking about using an alternitive blade is it has the same dimensions - I have seen cordless circular saw blades which have the right diameter and bore but the kerf are slightly different. Would this affect the rubber strip along the edge of the guide rails?
Thanks, Mark
Thanks, Mark
