Paul Chapman":38wv43e5 said:Setting up a plane and planing a piece of wood is a very basic woodworking skill.
sunnybob":s7t1wunp said:I'm taking one step forwards and two steps back here.
I made a ply base with thin strips of hardwood to act as guides. I can see how it would work for most, but i just cant get the plane to do whats its supposed to. Either it takes no wood off, or I have to repeatedly ram the plane across the wood (oak) and the plane skews sideways under the force I'm using. I've just turned one of my ragged but flat strips into a 600m wide wedge. i just cannot plane the wood square.
looks like the vice is on the back burner, and the planer thicknesser has just reached top of the wish list.
Ed Bray":3c5ch1c4 said:I don't know why you haven't tried my method, you could build it in about 10 minutes. In fact, I will go out in a minute and build one just to see actually how long it takes.
7 bits of wood, three for the frame, 2 for the runners and one for the end and a shim to plane to (plus some further shims for adjusting the thickness, you can add these later as required).
The plane can't skew because the frame is sized to the width of it, you can't cut a wedge (unless you want to and that would mean installing a wedge as a shim) because the runners stop you cutting when you 'get to depth'
You do need to be able to set up a plane though, although there are plenty of methods on youtube as examples.
I'll post some pictures of my effort in a short while.
sunnybob":12o2rjqt said:I have been unable to find any one on this island who makes small wood things as a hobby. I have even advertised island wide, and got zero response. i only know one wood worker in the uk, and he's a lathe man so I have nobody to help me, and the internet is the only source of information I have.
I thought I had the plane blades sharp, i've followed several you tubes on the subject. They have been working ok on ply edges and softwood, but against this oak, not a hope.
sunnybob":2ljm9ryg said:Droogs, i think I will downsize my aspirations, and go back to working soft wood for a while. I am obviously way out of my league with this oak.
I had some minor successes with mahogany when I started, I shall go back to it and stay away from hard woods.
Nicosia is a good hour on the motorway from me. I had seen the guy with the mobile work bench, but not the woodworking association. I shall contact them, thanks very much. I have tried to find evening classes here, but the language barrier is huge when dealing with ordinary workers. My greek barely passes the "good morning, & two beers please" level.
