Making saw-handles.
Ah the late lamented Alf.
Still we can't have everything I spose. :(
Cheers Mike
Unless I'm mistaken Alf, late of these shores and now to be found elsewhere, though her posts and reviews remain, wrote that article for the LV newsletter.
Cheers Mike
Not really in the same league as Alf's piece, but here's an old backsaw that I nearly chucked out when clearing out my old man's garage last year
It's got the old MOD mark on it so not that old or special, such teeth as it had were almost round in many cases :shock: :lol:
Anyway, decided to use it as a practice piece so cleaned up the blade with wet and dry and polished the brass back, refiled and set the teeth to cut rip (first time I've tried that but pretty easy).
Then decided to make a new handle as the old one was really shabby, used some iroko which was a bit boring but was to hand at the time.
Don't think I rounded the handle corners enough on reflection, and the wood looks a bit dark and bland on the saw, but feels comfortable and amazingly cuts very well indeed, so quite pleased all in all.
Then got carried away and decided to attack my old S&J which had a really tacky flat beech handle covered in dark, thick lacquer, so a bit of work on the blade and back, then copious filing and sanding on the handle resulted in this
Still the original handle so not the most elegant shape, but quite pleasing initial forays onto the slippery slope. May use some of the Yandles pau rosa and do a better handle or two now I have some idea of how to go about it.
Cheers, Paul. :D
Cheers Mike
Ahh Yes... Al Frampton is given as author. so you might well be correct!
John
I have a rather unlovely old S&J tenon saw with a loose handle that I'd like to fix up. The handle appears to be riveted on and I don't see an easy (non destructive) way to get it off. Any ideas? If/when I make a new handle, what is the best way to attach it?...I see what looks like brass machine screw heads in one of your pictures Paul. This probably won't be any time soon but I like to have a project or two on the back burner that I can pick up when I get stuck/bored/frustrated with whatever else I'm doing.
You can buy the appropriate nuts and screws (I believe Classic Hand Tools do them) or there's a good article here about making your own http://norsewoodsmith.com/node/108
Cheers :wink:
Paul
Lots of people on the Forum have made replacement handles including one I did on a new Crown saw:
Workshop Heaven sell the screws at £1.75 each
Rod
chisel":3aa7ga8q said:
...refiled and set the teeth to cut rip (first time I've tried that but pretty easy).
That's interesting. I imagine most saws are sold with a fine cross-cut setting, because I find it can take a short lifetime just to cut one tenon. Do you find it cuts much faster with a rip-cut pattern?
I bought an old Spear & Jackson saw off eBay myself a couple of years ago for £12. It's in great condition but could really do with a sharpen - this thread has given me some other good ideas too! :wink:
Hi Olly,
Yes, thats exactly what I think it will get most use for now, cutting tenon cheeks, the rip profile does indeed make it cut nice and fast on those.
Couldn't be bothered with all that talk of filing and setting and stuff before, more interested in the actual woodworking, but having salvaged an old saw myself now and seen how well it performs afterwards it is very satisfying indeed, although there is still plenty of scope for better handles on my ones.
Cheers, Paul. :D
Very interesting what can be done with an old saw. I have 2 old back saws that was my fathers from the old days. This will be my next job. Can someone recommend a tooth set tool.
Doug
sorry to jump in on the chat, but have read with interest, and am considering sharpening my old tenon saw, using an eclipse tooth set. Will this do? It is the grey/gun metal coloured one with a sort of magnifying glass bit.
I only figured out what it was a couple of months ago!!!
Thought it was a riveter!!!
Thanks gents....
Thanks gents....
Neily, the saw set is for setting the teeth after sharpening with a saw file. You also need some sort of saw vice to hold the saw blade while you work on it. Have a look on the handtools forum for some of Bugbear's posts on saw sharpening.
I had a play around with my old S&J tenon saw tonight and got the handle off ok. It turned out that it did have split nuts after all, so it came off easily. All I need now is a good pattern for the new handle.
