Phil Pascoe
Unless of course you offset the cutter as Chipmunk has done. It's two tools instead of one I suppose, but if you're using carbide cutters, the main cost is the cutter rather than the rest of the tool.
Your last paragraph sums up what I was getting at - if hex bar were used, would it be a worthwhile compromise? I suppose logically the cost of making the tool is small enough to justify making all combinations of bars and cutters, then keeping the ones that suit best.
