Dissolve
I have two holes which I've decided are too far off centre for my liking, I've decided to plug them and re-drill them correctly. The repair will be under a translucent finish but might be covered in the end, so this just seems like good practise to make it as seamless as possible
The holes are currently 4mm in diameter, but I'm not sure if it is more sensible to drill them out to 5/6mm before starting the repair? It seems making the plugs slightly larger may be easier in the long run?
The repair is pretty much entirely cosmetic, so the plugs/dowel I make will need to be made from the same timber, and obviously needs to match the grain once inserted/sanded flush. All the information I can find on making dowel for repairs involved hammering a roughly shaped, strain grained piece of stock through hardened steel holes, but I doubt this would work very well once the material is rotated to have the side grain as the face of my plug/dowel.
I have a belt sander and a bandsaw, so I can get close by ripping some square timber and sanding/planing my way close to cylindrical,I just wondered if anyone has a tip or two on making plugs for good looking repairs?
(the holes are only being shifted .5mm or so, and I've encountered stripped screw holes in wood many a time that I've always repaired using off the shelf dowel where the looks aren't important, so it seems like time to practise making plugs for aesthetically pleasing repairs!) :lol:
