ScottyT
i am currently nearing the end of making some hinges for a fairly big gate as far as pedestrian gates go.
I haven’t documented the making of the gate as it differs very little to a previous post I put up here on the same theme, and it’s a bit of a ‘you’ve seen one you’ve seen em’ all’ kinda style.
That said it does have a top rail that includes the curve and capping in one hit, I’ll explain a little more about that further down the thread.
I do my own metal work as it keeps me in control, I enjoy it, it breaks the weeks up a bit from the woodwork and I feel the joinery background crosses over hugely into metal fabrication, things like marking and measuring accurately, practical thinking and the approach to the task is all the same or similar.
I have only basic tools which is all I need for what I do, consisting of a good quality MIG welder, an angle grinder, various clamps, a selection of hammers and holding tools, a forge and anvil (the anvil is just about ok to use it has seen better days but does a job until I can get my hands on something in better shape) and a metal bench I made for working on.
I also have a lathe that’s invaluable in my home workshop that I use for keeping my old motorcycles on the road, brought years before I started metalworking but comes in handy all the time!
Basic overview for this job is a curved top rail, with really quite a tight radius cut into it, and a straight bottom hinge for the bottom rail.
Here’s the template for the top rail of the gate, my top hinge will need to follow this radius, it’s quite tight but more than doable with a bit of patience.
First up is to get some heat going to aid in bending the metal, it’s ideal weather for it too as it’s been fair cold this week in the south west of England, beats the rain any day though.
The forge I have is fed air from an electric fan, and is controlled on a simple slide gate that increases or reduces flow depending on gate position. Once I have the metal hot I can set a bout starting the bend.
To start the bend I put the metal on the anvil and strike one edge, this forces the metal to stretch along its length, and as it’s only stretching on one side it will start to form a radius
This is shown In the below photo
I don’t want to hit it too much as it’ll get too thin so I use the horn of the anvil to really manipulate the curve, being careful to not totally distort the material in doing so. I just keeping heating the metal and have a few blows on it and the repeat repeat repeat until the desired radius is achieved.
Once both curves are done I can get them on the template fabricate the rest of hinge.
They follow the template pretty well, it’s a awkward one this as the top straight sections are 6” wide and diminish to 5” though the bottom of the curve then increase again to 6” on the following side. Still, nothing major just something to be aware of. Thee above photo shows to score lines for cutting, and the photo below shows them after cutting, ready to receive the next piece.
The ends of the hinge have this detail on them, a homemade scribe, mdf template and the angle grinder cracks these out in no time, I have beaten a similar detail to this in the past with the hammer and anvil, but these need to remain flat to match an existing pair of gates the client already has.
Next up is some welding.
