I recently replaced a rotted box sash sill in my house using hand tools. It went well so I've decided, perhaps naively, to go further as there are a lot of them requiring new sills and sashes. The wife wants new double glazing all round but keep the traditional look, everything is original single glazed turn of the century and very lovely. It would cost a fortune to buy in.
Since doing the sill, I have an Axminster table saw, a planer/thicknesser and a router. The plan is, after first making some jigs/sleds, to try a small test sash, see if I can't get reasonable results and understand the construction methods and procedure. If successful proceed to full size and start replacing some of the sashes that have rotted in the existing boxes, but use double glazed panels (and heavier weights), if that's possible given the existing sash thickness. If THAT goes OK I'll try to build a full window and start replacing/refurb bit by bit.
We had some casement windows fitted in a loft dorma a few years ago - these were sapele and they move a lot. Had to plane them because the sashes jammed. With that in mind wood choice is going to be very important, I'm thinking of using Woodex RedGrandis or Woodex Softwood if I go all in DIY. Maybe Sapele or Cedar for sills? But I have zero experience with choosing timber, this is purely from researching online (including here). How is woodex to work with for a noob?
I want to go traditional as much as possible and use linseed paint for finish. Will this affect wood choice?
Am I mad to think this is even doable?
