My box frame repairs are very similar to
@Ollie78.
I take out the pulley stile, cutting at the point just above the bottom of the meeting rail of the top sash which hides the join permanently. I always make the new pockets bigger as I’m usually replacing for longer weights which won’t fit through the original pockets.
Then take out the cill. It’s easier now the pulley stile is gone since that is rebated into the cill. The more rotten, the easier it is to remove.
Tip when cutting through the cill. Take off internal mouldings first or use a multi tool to separate if leaving in place and before you finish the cut, crowbar up the cill slightly and you won’t run the saw over the concrete cill.
Take measurements of the distance between inner and outer faces and the distance between pulley stiles (both measurements at the top of the frame) and compare to the bottom. Any discrepancy can be a problem if draught-proofing. The top of the frame usually remains more stable and is a more accurate indication of original dimensions.
Cut new cill.
- Two rebates to hold the pulley stiles. Distance between rebates to match the measurement taken from the top of the frame. This keeps everything square (or straight at least) Drill 3-4mm holes right through the bottom of the rebates to help drain future ingress of water.
- extend the cill section min. 1 3/4” past the pulley stile, cutting a ‘tenon’ on the ends of the cill with the width matching the distance measured earlier (between outer/inner face at the top). The thickness of the inner lining dictates the distance the tenon is offset so that the cill sits flush with the inside of the frame. Some cill designs extend out past the outer lining but in all cases they are flush on the inside.
Now sort the weights out whilst you have good access (pulley stile is cut away).
Assuming rot in the outer lining, cut it away but always at least 6” below the cut you made in the pulley stile. This staggers the repairs and is much stronger. The cut needs to be angled downward regardless of whether straight scarf or step-joint.
Obviously, replacing the whole length is preferable but not practical in most instances.
Before making any cuts in the inner lining (and as long as your happy with its position) use it as a reference to locate the new pulley stile, which you cut earlier with the relevant tongues on each side, parting groove etc
Sometimes the cill can be slid in from the front, other times it needs to be placed from above before the new pulley stiles go in.
Move the cill side-to-side until the pulley stiles are square with rest of frame. Pin the inner lining to the pulley stile to hold everything in place. Don’t tap pins home if replacing inner lining.
Replace outer lining. Blah blah.
Now change inner lining as appropriate. Blah blah.
Now take everything out, sand everything, prime the bits that need priming, realise you just took out all your references, realise it doesn’t matter cos you’ve done this a thousand times before and you made quick and experienced notes and pencil marks on the masonry, frame, phone and photos, knife marks in places where pencil marks would get sanded off and/or primed over, made mental notes where you thought that cos you’ve done this a thousand times before that you don’t need written references, then forget, then remember as it’s going back together just in the nick of time.
I could drag this post out to ten thousand words just on this one type of repair and that actually, this represents a fraction of potential scenarios, window designs, location in the wall, potential problems and a million other things to look out for. I also realise that it’s incredibly difficult to know what I’m talking about unless ‘you know’.
Welcome to the world of sash window repair.
Oh and one more thing. Dryseal for the splice joints. Glue will never do. I don’t care how good you think your splices are.
Oh yeah, pack the cill up on slate and make sure the pulley stile and outer/inner linings are cut shy of the stone cill. This means you need to make the replacement cill slightly thinner or simply use it as a good excuse to trim the sashes which means you need to take out the sashes and errrr……’it’s just a window right?’ ‘Why does it take so long?’ ‘Can’t you just?…..’. No. No I can’t. Or rather, I won’t. I don’t want to. I do it properly or nuffink.
Yeah.
