Fidget
Trying
Did you get a new zero clearance insert made? I’ve got the SIP 01332 and looking to make a new insert myself.
I made one for my Itech 01332 (same machine) out of Valchromat, bought a couple of A3 size bits from The Bay.
I cut it roughly to size then stuck the original plate on with double sided tape and used a template follower bit on the router table to trim it to size. Marked the mounting holes while it was still taped. Then I used an ordinary router bit in the table to gradually thin the edges down until it fitted snugly in the slot. Drilled and countersunk the screw holes and put another larger hole in so I could lift it out. Then put it in the slot, clamped it with the fence and raised the blade, turned it over length for length and did the same again which nearly cut a slot long enough for the riving knife. If I remember correctly I had to use a small file to make it about 3 or 4mm longer so that the riving knife didn't foul the slot at full height. This one is about 2 years old now, I made two so I have a spare
HTH
