Quick update on this.
After playing about with some more experiments, using different scraps of wood and different sized preliminary holes, I found I was getting a very sloppy fit. This is the reason why:
I'd made the tap 1/16" of an inch oversized.
So, it was back to the lathe, being pleased that I hadn't changed the way it was set up, or removed the end holes in the tap. A few passes with a file while the work was spinning removed enough material from the diameter, but that left teeth that were too shallow. I managed to line up a cutter, with the leadscrew set to work at the right tpi, and follow the original angle close enough. I really don't think I would have been able to do this with a powered lathe or a finer thread. As it was, I was able to pull the lathe round by hand, scraping away on one side of the thread, to deepen the teeth.
A few passes and it felt like it would work, and it does.
Sharp eyed readers will notice the addition of a cross-bar and retaining screw as well.
Now I could use the tap and box combo to make something, but I'll put that in the Projects, as it's wood, not metal.
