See attached photo:
How would I do this , assume I would run a rebate first then machine the moulding?
Seem to be plenty of sizes of Ovolo router cutters but not much of a choice when it comes to spindle knives. Does this mean I should thinking of having a set made up with matching limiters? Or do I make up the the mould profile by using only part of a knife profile then adding fillets from another knife,sort of building up the shape, seems to be quite a lot of accurate setting up going down that route.
Or is to do with using a large diameter spindle Ovolo cutter, as it has the same radius all around, would I move the cutter in deeper to get the Ovolo size I want, if so, what about the fillets?
Cheers.
Cheers.
