alex robinson
I am looking to buy a new sharpening system to replace my ancient record scan 150 with a wonky cracked wheel and no option to take jigs. This may be the first "finished" bit of the workshop that I won't want to consider replacing with a bigger better version in some probably fictitious future, so I want to get it right.
I am currently looking at either the Sorby Proedge or the Axminster Ultimate linisher. I like the sound of being able to change belts to allow reprofiling and fine sharpening on the same machine. The Axminster is significantly more expensive (similar to the Sorby with all the jigs) but I have read reviews here that say it is the better machine. What do people think?
The Sorby comes with a selection of jigs. The Axminster says it is compatible with Tormek jigs, but these make an expensive machine even more so. Will either of them fit cheaper versions, such as the Record gouge jigs? I will mostly be using it for turning tools, but I dabble in flat woodwork so a few chisels and plane blades. I am definitely not someone who wants to get into competitive chisel honing however!
Alternatively a CBN set up may end up a similar cost. Is there any reason why this would be significantly better? What machine would people buy to go down this route, as I cannot see any kits offering this from the outset. It seems a waste to buy a new grinder and replace the wheel before even using it.
Thanks!
Thanks!
