Homeless Squirrel
How do likes of Luban and Quenshang? stack up against likes of Stanley etc
Ive got a Stanley 9 1/2 knuckle plane with SW blade it's good in fact very good can makes Rizla papers from a lump of wood!Heavier, harder irons.
I think the old stanley planes had softer blades for site work. I've rehardened a couple and they have the potential to be harder than the A2 irons in the newer planes, so it was deliberate on stanley's part, probably to make sharpening those irons easy.
I've never cared too much personally for the low angle block planes. If there's appreciable end grain to plane, they are really the last plane you'd want to do it with despite demonstrations of that. The extra 8 degrees on something like a 9 1/2 gets you closer to a pitch that won't tear out too much on long grain, you can still bevel and do whatever on a small scale, and the wear bevel literally doesn't appear on the back of the iron whereas it will leave a pretty long wear bevel on a low angle block plane.
It used to be that low angle mania made 9 1/2s cheaper, but it no longer does.
i don't see the virtue of a heavier block plane, but people trying to use them to plane vast amounts of end grain might.
Like all of my other posts, I've had premium versions of these in the past and no longer do. I got suckered into them by watching gurus do things like plane the end of a drawer with them, but they are not made for that and it's just a good way to have sore fingers.
I do like the rehardened stanley irons better (than the originals, and far better than A2 irons), but a buffer on a softer iron also deals with their softness, and even the softest stanley irons will plane bubinga and cocobolo if that's done.
Must admit picked up a mint Millers 14 for £40 posted other day.friend said other looked better but went with this and it's spot on and just feels so nice in the handMost of the older block planes I've gotten suffered some kind of fitting with the moveable mouth. I've cleaned each of them that I've had and then lapped them and they are a treat. They are probably the easiest thing anyone could find to lap, but I also think once the shoe is locked in place and lapped, moving it around much is asking for issues. So I have not ever allowed one to move
