novocaine":wgozracq said:how do you get a 1/4" shank on a 6mm spade bit?
Yes they can wander a bit. It all depends on what you want to do with the hole. But they are fast, cheap and easy to sharpen.phil.p":2xgq3jvq said:Same way you get a 1/4" shank on a 6mm router cutter?
I assume the OP is looking for at least a degree of accuracy, so whether a spade would work is debatable.
