If laminating timbers, and being conservative, I think its good policy to use the bench as a reference and not relying so much on much technique.
If using this method, it will be fairly obvious. half of what's invisible to the naked eye, I'd guess.
I haven't checked what that is with a feeler, the test for that is if the timbers will sit without a gap.
The amount will likely be relative to the length of timbers you're planing most often.
i.e more forgiving on longer lengths.
I will be doing the same idea with a single shim under the middle on another bench, if need be, and expect to have to do some adjustment from time to time, and keep an eye on it,
More of an issue to get longer stock bang on, than concentrate on always taking a through shaving every time on shorter work, which is nice when its flat.
