Steve Maskery
A while ago I asked for advice on a small router. I bought the Hug Flight and am generally very pleased indeed with it, so whoever suggested it, Thank You.
There are a couple of niggles. The cable is stupidly short, so I've fitted a 3m cable instead. It only needs to be 2-core, but I forgot that and bought 3-core. The earth is redundant.
The other thing is the size of the base. Well it is supposed to be small, off course, but it is easy to tip. So I've made an offset base to give me more stability.
The material is an old shower tray panel. Big mistake. It is too flexible and the router bounces a tad. So I've remade it with some 6mm phenolic (at least I think that is what it is - it's certainly hard and rigid) and that works much better, no bounce at all. The only slight cockup is the hole positions, they are not quite right. I don't understand why, though as I poked through the originals, so it's held on by only two screws rather than 4. But that's fine.
So with that base I can flush off applied edgings or use a bearing bit to round over, and there is much less chance of the tool tipping.
I'm seriously thinking of getting another one and keeping one permanently set up like this.
