Lidl 5-in-1 Multi-purpose detector
I expect it will worth what you paid for it.
Dont expect too much from laser level. I've seen some quite expensive ones with 3 mm per metre tolerance
Slightly worrying that the "details" button is inoperative :shock:
I think I might have broken my lidls record of buying junk. Just bought a soldering gun with a reel feed worked by the trigger. It actually DOES feed solder to the tip!!!!!
And its "claimed" to be 60 watt, which is enough to burn wood with the point. 8) 8)
I have one and it's rubbish at detecting. But the sonar distance measuring is useful...
Sent from my Nexus 5X using Tapatalk
That is good to know, I was hoping the distance measure would work, main reason I got it.
I paid £80 for a Bosch wall scanner which doesn't really work so was not expecting much from the Lidl one!
