Got asked to make a new handle for a tool I've never seen before. Original handle had cracked down the middle and was being held together with gaffa tape - quite valiantly I might add. Original was made from ash which is quite fortunate because I have a fair amount of it in stock. I initially found the centre line of the tenon that mates with the tool head and turned it on the lathe. I then traced the profile onto the square edges and cut it out roughly with the bandsaw and then rounded the shape down further with a belt sander before getting the end result using a spokeshave. Finish is tung oil. Not normally a project I would get involved in but I'm quite pleased with the result.
So the big question is, can anybody name the tool or even the trade that uses it? Was quite interesting to hear about it and it's use from the owner.
